AutoCAD Plant 3D Forum
Welcome to Autodesk’s AutoCAD Plant 3D Forums. Share your knowledge, ask questions, and explore popular AutoCAD Plant 3D topics.
P3D 2014: Catalog Problem with the actuator dimesions
3 REPLIES 3
598 Views, 3 Replies
Hi to all!
i have a problem with the actuators which are cubic. (sorry for the worse english) see attachment.
in the properties there are
ActuatorHeight:
ActuatorWidth:
these 2 ones are taken for the size of the actuator. what is with the other ones on the right side?
for example: it does not change the size if i set the "H" dimension smaller.
does anyone has the same problem?
thanks for your help!
Mario
3 REPLIES 3
no one has this problem?
SEATEN
I have the very same problem. Did you solve it?
no i didn't solved it. maybe it changes in the 2015 catalog.
”Boost
