AutoCAD Plant 3D Forum
Welcome to Autodesk’s AutoCAD Plant 3D Forums. Share your knowledge, ask questions, and explore popular AutoCAD Plant 3D topics.
P3D 2013 - Where did my shortcut menus go?
8 REPLIES 8
Message 1 of 9
dzine14u
6006 Views, 8 Replies
I finally got around to installing and setting up P3D 2013.  The only issue I seem to have is that the right-click shortcut menus do not seem to work at all. I have triple checked in Tools>Options that my settings are correct and are like they have always been yet the menus never appear. There must be another problem that I am not aware of.
Is there a fix to get my right-click shortcut menus back? Please help.
Chuck Altmix
Lead Engineering Designer
Upper Consulting, Inc.
www.upperconsulting.com
8 REPLIES 8
Message 2 of 9
Venkatesan.A
in reply to: dzine14u
Can you try typing at the command window "shortcutmenu" and set the variable to "11"
Venkatesan.A
Support Specialist
Product Support
Autodesk, Inc.
Message 3 of 9
dzine14u
in reply to: Venkatesan.A
Thank you for your response but unfortunately it didn't work.
Chuck Altmix
Message 4 of 9
Venkatesan.A
What actually happens when you right click? does it show any variable in the dynamic input?
Try entering the variables 1 or 2
http://docs.autodesk.com/PLNT3D/2011/ENU/filesACR/WS1a9193826455f5ffa23ce210c4a30acaf-4e99.htm
guess we should check whether bit 1 (and maybe 2) of shortcutmenu is ON.
Let me know.
Venkatesan.A
Support Specialist
Product Support
Autodesk, Inc.
Message 5 of 9
dzine14u
I have tried every possible variable setting yet there are no right-click shortcut menus that appear. When I select an object then right click, all it does is repeat the last issued command. So the shortcut context menus never appear no matter what the variable is set to.
When I look at CUI all of the shortcut menu data exists. Note that the results are the same regardless of which set of workspace menus are loaded.
I have attached a screenshot showing that the shortcut menus are turned on and the right-click customization settings. Thank you for your help.
Chuck Altmix
Message 6 of 9
dzine14u
I still have no solution to this dillema.  I would really like to find a way to return my shortcut right-click context menus.
Chuck Altmix
Message 7 of 9
Venkatesan.A
Have yout tried these ?
http://forums.autodesk.com/t5/AutoCAD-2011/Right-click-Not-working/td-p/2919024
Venkatesan.A
Support Specialist
Product Support
Autodesk, Inc.
Message 8 of 9
Venkatesan.A
I know you must have tried a lot of troubleshooting but just checking with you incase you have missed any of these.
did you try this option type "PICKFIRST" at the command window and set the value to 1, or, goto TOOLS>OPTIONS>SELECTION and make sure the noun/verb box is checked.
If this didnt work try the repair option, still didnt work I guess you will have to reinstall.
Venkatesan.A
Support Specialist
Product Support
Autodesk, Inc.
Message 9 of 9
mmills
The Noun Verb thing worked grreat for me.
”Boost
