AutoCAD Plant 3D General DIscussion
Active Contributor
3 Kudos
Post 1 of 6
P3D 2013 isometrics PIPELINE-REFERENCE field
599 Views, 5 Replies
09-04-2012 04:19 AM
Sea attached a sample.
My P3dLineGroup.tag is 80 P 80032 A2.
When i generate isometric and PCF file, the name of PCF file is correct, but inside PCF file the PIPELINE-REFERENCE take the value "80 P 80032 A2-2". From where P3D add the "-2" ??
The consequences are that on iso line tags this "-2" appear too ! (because isoconfig.xml use the PIPELINE-REFERENCE field)
So :
How the PIPELINE-REFERENCE field is generate from model to PCF file ?  (I did found that in isoconfig.xml)
Where does the index "-2" at the end of the number ?
Regards
Sam
Product Support
16 Kudos
Post 2 of 6
Re: P3D 2013 isometrics PIPELINE-REFERENCE field
09-07-2012 02:23 AM in reply to: SamScopeo
Hi Sam,
The 2 after your user-defined tag is a reference numbe to the splittet isometric drawing. See attached picture. If your isometric will be splittet in two drawings 80 P 80032 A2-1 and 80 P 80032 A2-2.
Regards
Bernd
Bernd Gerstenberger
Active Contributor
3 Kudos
Post 3 of 6
09-07-2012 02:51 AM in reply to: gersteb
Hi Bernd,
True the iso spleeted have an indice added in dwg name and file name. I get it.
But there is only one PCF file and only one PIPELINE-REFERENCE per line (even if it's iso is spleeted)
So sorry but it is not normal to have this indice in PIPELINE-REFERENCE of PCF file :smileysad:
Regards
Sam
Active Contributor
3 Kudos
Post 4 of 6
09-07-2012 04:07 AM in reply to: gersteb
Hi Bernd
See attached, even if the iso is not splited, this indice appear ...
Sam
Product Support
16 Kudos
Post 5 of 6
09-07-2012 05:17 AM in reply to: SamScopeo
This is strange. I can not recreate it here. I tried also to migrate a 2012 project to a 2013 project. But get no added number at the end of the tag as you get when isometrics are not splitted. I will send you via email a ftp-link there you can upload your project.
Bernd Gerstenberger
Valued Contributor
0 Kudos
Post 6 of 6
10-17-2014 08:52 AM in reply to: gersteb
Is there a solution to this problem?
New AutoCAD Plant 3D Category!
The AutoCAD Plant 3D forum has moved into it's very own category page, and can no longer be found within the Additional Product Forums.
