AutoCAD Plant 3D General DIscussion
Valued Contributor
Rcfuss
Message 1 of 2 (273 Views)
P3D 2012 Isometric Fabrication-Item vs. Erection-Item
273 Views, 1 Replies
05-05-2012 10:04 AM
I wanted to place Valves, Instruments,Supports,etc.  in the the Erection Category without changing it in the .PCF file.  Are there settings in the isoconfig file that dictate which category these items get placed in?
Thanks in advance.
Robert C.
Middough Inc.
There is a property for each 3d object in your model called "Shop/Field"
Your fabrication items should be set to Shop and Erection items set to Field. Looks like the settings within your ISO Border/Table Settings is set correctly, with the splitting of Erection and Fabrication items.
Muddy_Plant3D
Message 2 of 2 (266 Views)
Re: P3D 2012 Isometric Fabrication-Item vs. Erection-Item
05-05-2012 03:43 PM in reply to: Rcfuss
Jarrod Mudford
Plant Solutions Consultant
Global Services
New AutoCAD Plant 3D Category!
The AutoCAD Plant 3D forum has moved into it's very own category page, and can no longer be found within the Additional Product Forums.
