AutoCAD Plant 3D Forum
P3D 2012 - File Name Format
5 REPLIES 5
dennis
879 Views, 5 Replies
I want to do something a little different than what the default interface seems to be able to do for File Name Format.  I want to concantenate different data: Project Number - DWGType - DWGNumber - Sequence Number where Project Number is the same number entered on the Project Details, DWGType is a list of letters <example; D=PID, A=Architectural, I=Iso., and DWGNumber is the same as the number added in on the Properties of the DWG itself, Sequence is just user entry numbers <001, 002, etc>.  And here is the kicker, I only want to put this data in once.  I can get it to do what I want provided I am willing to fill out the info twice.
So, is there a way to create a field in P3D File Name Format that will concatenate other fields together to produce the name I am after?
5 REPLIES 5
Dan.Scales
in reply to: dennis
Hi Dennis,
You can use the command PLANTDEFINECALCPROPERTIES to combine properties.
I have not tested using it to create a file name format as it is an undocumented and unsupported command so you will really need to try it yourself.
Hope this helps.
Dan
Dan Scales
SrPiper
in reply to: dennis
Hi
did you solve this file name format problem using the PLANTDEFINECALCPROPERTIES command?
thanks
dennis
in reply to: SrPiper
No, the File Name Format cannot access any Field or Drawing Properties data directly.  I ended up writing some .NET code to do what I wanted.
ae_m44
in reply to: dennis
can you tell me please how to do that?
AE
berimahcroffie
in reply to: dennis
Can you please share your code? or how you did this?
I am searching for exactly the same.
Thanks in advance.
”Boost
