AutoCAD Plant 3D General DIscussion
w.shafer
Message 1 of 2 (201 Views)
P&ID's & Model
201 Views, 1 Replies
04-22-2010 01:40 PM
If a set of P&ID's and then a 3D model are created with ACAD Plant 3D, is there any kind of relationship between the P&ID and the model through the database where a change in the P&ID results in a notification in the model that a change has been made? Conversely, if a change is made in the model, is there some kind of notification in the P&ID?
Employee
gulnacm
Message 2 of 2 (201 Views)
Re: P&ID's & Model
04-23-2010 03:25 AM in reply to: w.shafer
Try the Validation tool. This will compare Plant 3D to PID data and report missing or incorrect information. Th
Mike G (Autodesk)
Michael Gulnac
Technical Specialist
Organization
New AutoCAD Plant 3D Category!
The AutoCAD Plant 3D forum has moved into it's very own category page, and can no longer be found within the Additional Product Forums.
