Bittlelum1,
We currently don't have plans to make a P&ID object enabler and I'd like to
better understand your need for one.
Our thinking is there are a few ways you'd want to share a P&ID with someone
else.
Suppose you are in the middle of an engineering project and you want to
share a P&ID with someone who doesn't have AutoCAD P&ID. They can't change
the P&ID and maintain the data but they can view it, plot it, or mark it up.
If they make mark ups, you can take back the P&ID and make the required
changes. If you open an AutoCAD P&ID in plain AutoCAD, you'll get proxy
objects that should look identical to the regular objects, but they can't be
changed. This is probably what you've been seeing.
Alternatively, if the person you are working with has AutoCAD P&ID, they can
change it and make edits that maintain the data, and return it to you.
If you need to deliver a P&ID that is fully editable by the person you're
sharing the drawing with, but doesn't have the data, use the Export to
AutoCAD function. We think this is most useful when you need to deliver a
drawing to your customer at the end of a project. The P&ID must live on and
you can't rely on the customer having AutoCAD P&ID to be able to edit it.
Do these scenarios match how you are using AutoCAD P&ID? Are we missing some
scenario where having an object enabler would be useful?
Peter Quinn (Autodesk)
wrote in message news:6366368@discussion.autodesk.com...
Thank you for the information.
Any Idea when the OB for P&ID will be available? Next Release?
