I'm trying to understand P&ID to Model mapping and looked at "Map PID and Plant 3D Classes and Properties". The example that was supposedly from Data Manager didn't even resemble DM in version 2013. Then I discovered that the above document was for version 2010! Is there any documentation on this subject that's been updated to Plant 3D 2013? I can find nothing on YouTube either. There just doesn't seem to be any updated information, just like Bolt Mapping. This is very frustrating.
Solved by Grampster. Go to Solution.
Did you read this:
First of all, mapping is basically telling Plant 3D how to treat P&ID parts, and which properties correspond to Plant 3D properties.
You don't have complete flexibility as the classes have to be related to each other, so it's mainly for properties.
The mapping process hasn't changed really. Although for 2013, they did fix it so that if you use valve substitution, the tag remains.
The biggest thing you need to watch out for are adding new classes to the P&ID side. For example, if you add a bunch of new line types, you'll have to add the mappings so Plant 3D knows how to handle them.
Thank you for the update. As I said, the one I was looking at was for Plant 3D 2013. I'm printing it out now.
