AutoCAD Plant 3D Forum
Welcome to Autodesk’s AutoCAD Plant 3D Forums. Share your knowledge, ask questions, and explore popular AutoCAD Plant 3D topics.
P&ID - No attachement points and flow arrows
2 REPLIES 2
458 Views, 2 Replies
I am evaluating autocad 3D plant 2015 for my company. I created a new P&ID drawing in a new default project. I picked 2 equipements (pump and vessel) from the tool palettes - P&ID DIN and placed in the drawing. I picked a general pipe line and tried to connect the 2 equipements with this pipe, but I see no flow arrows en no attachement points on the drawing.  What went wrong or what did I forget ?
2 REPLIES 2
KenFauver
Instead of using the Default project create a new project and see if you have the same issue.
If the post answers your question, please mark it as an Accepted Solution, so that others can find answers quickly!
Kenneth G. Fauver
Technical Sales Specialist – Plant
Oil and Gas Solutions
patpat79
in reply to: KenFauver
Does the snap is "ON" ?
Best Regards,
Pat Andres
Autodesk Expert Elite
Plant 3D Administrator
GHD Manila
”Boost
