AutoCAD Plant 3D General DIscussion
Active Member
cooldici
Message 1 of 17 (648 Views)
Accepted Solution
P&ID Error
648 Views, 16 Replies
03-28-2013 03:08 AM
Dear All,
When  I try to add some equipments to a P&ID, Warning appears "this tool is not supported in a non PNID drawing file"
Please check the jpegs attached.
How can I fix this problem? I updated my Plant 3d service pack and everything but nothing changed. Please help me :smileysad:
Satır içi resim 1
Satır içi resim 2
Active Member
cooldici
Message 2 of 17 (578 Views)
Re: P&ID Error
04-01-2013 08:02 AM in reply to: cooldici
It is so bad that I am the only one has this problem:smileysad::smileysad:
Valued Mentor
ybogdanov
Message 3 of 17 (571 Views)
Re: P&ID Error
04-01-2013 01:07 PM in reply to: cooldici
Could you turn to attach your images another time. It's not appear in post.
Yury Bogdanov
ASIDEK(Grupo CT) - Partner Directo de Autodesk
Barcelona (Spain)
Active Member
cooldici
Message 4 of 17 (549 Views)
Re: P&ID Error
04-02-2013 06:37 AM in reply to: ybogdanov
Here you can find the photos attached.
Valued Contributor
eadkins73
Message 5 of 17 (528 Views)
Re: P&ID Error
04-02-2013 08:11 AM in reply to: cooldici
Was this drawing created in Plant3d?  If so, was it created as a P&ID?
Active Member
cooldici
Message 6 of 17 (524 Views)
Re: P&ID Error
04-02-2013 09:19 AM in reply to: eadkins73
yes and yes. Here You can see what happens step by sted in the attached pdf.
Valued Contributor
eadkins73
Message 7 of 17 (519 Views)
Re: P&ID Error
04-02-2013 09:50 AM in reply to: cooldici
Thanks for the step by step.  I have had this happen to me.  For whatever reason when a drawing is created through the project manager ACAD puts some kind of identifier in the background to tell plant that is a PnID or Ortho or Iso or whatever drawing.  So for example, if you tried to copy an othro drawing to the project in to the models folder you would get an error message.
Having said that, my only guess is that the template you are using for the PnID was actually created in some other folder and the program doesn't recognise it as a PnID.  So try making a new dwg from another template and see if that will let you add the components.  Then you should be able to cut and paste.
Ed
Active Member
cooldici
Message 8 of 17 (499 Views)
Re: P&ID Error
04-02-2013 01:24 PM in reply to: eadkins73
It happens to me even if i create a new project. How come it doesnt say that it s a Non PID drawing when i am using a PID template drawing???Adsız.png
Valued Mentor
ybogdanov
Message 9 of 17 (491 Views)
Re: P&ID Error
04-02-2013 01:58 PM in reply to: cooldici
I send you message. I think that it's happen because your path of direction project is too large. Move it to Desktop or create virtual disc in "My PC" of windows...
Yury Bogdanov
Barcelona (Spain)
Active Member
cooldici
Message 10 of 17 (488 Views)
Re: P&ID Error
04-02-2013 02:09 PM in reply to: ybogdanov
You see how short is the path. And here is the same problem:manmad:
Announcements
Need installation help?
New AutoCAD Plant 3D Category!
The AutoCAD Plant 3D forum has moved into it's very own category page, and can no longer be found within the Additional Product Forums.
