AutoCAD Plant 3D Forum
Welcome to Autodesk’s AutoCAD Plant 3D Forums. Share your knowledge, ask questions, and explore popular AutoCAD Plant 3D topics.
P&ID connectors in same drawing
3 REPLIES 3
Arun_Kumar_K
609 Views, 3 Replies
What is the way to keep connectors in a same drawing in P&ID?
3 REPLIES 3
Hi Arun,
You should be able to get same numbers. Please check the help thread below for more information,
http://docs.autodesk.com/PNID/2010/ENU/AutoCAD%20P&ID%20User%20Documentation/index.html?url=WS1a9193...
If its different, can you able to elaborate on your request.
Vinod Balasubramanian
AutoCAD Industry Support & Escalation Lead
Vinod, can u brief the purpose of Tie-in in P&ID
If you have an existing pipe or installation and if you want to connect some other eqipment or pipe later during your design stage or in future, the point where you define this is called a tie-in point. IN our P&ID you can find tie-in points under the non-engineering tab in out tool palette. However tie in is not a Autocad P&ID unique feature, it is more off a practice in industry.
Hope that helps.
”Boost
