Hello All
I am A big Problem.
I have two P&ID Drawings 0298-PID-01 and 0298-PID-02 when i change the line number in a Line Number in PID-01 the line number Chage too in PID-002
Help Me Please
Juan
See the Video
Have you tried to just erase the line in your 02 drawing from the tank to the end cap? Then redraw the line and see if it will then allow you to change the line number without it updating the line in drawing 01.
Quentin Contreras
Technical Support Specialist
When you assigned the line number of the second line to 001, you are joining the two lines together. You're not creating two separate lines with the same number.
Even when I change the line number with the other p & ids closed. Ciando open them tells me that they must change
If you need two lines with the same number but different services, you should change the tagging format to make these two fields inforce uniqueness, not just the number.
Thanks Peter Quinn for your quick Support
Can you Helpme How change those items?
see my line configuration
Peter
How can i do this ?... My client has defined its standard initialized the number of line when change of service
In Autocad Plant 3d is not possible made this?
see my client reference drawing image
Thank a lot for your collaboration
