AutoCAD Plant 3D General DIscussion
Valued Contributor
vannmannen
Message 1 of 2 (189 Views)
Out of Spec item - leakage + 'open end' on iso
189 Views, 1 Replies
08-18-2012 10:00 AM
I have a filter with DIN flange, while the connecting piping is ANSI.
First I place the DIN flange to the equipment and then I place an CS150 elbow to the flange. The connection between the DIN flange and the ANSI elbow shows a leakage point + the isometric separates the ANSI line and the DIN flange into separate drawings showing 'open end' connections.
How can I force Plant3D to accept the connection, or alternativly; force the iso to show connecion + spec break?
Employee
TomislavGolubovic
Message 2 of 2 (160 Views)
Re: Out of Spec item - leakage + 'open end' on iso
08-19-2012 03:48 PM in reply to: vannmannen
Its probably missing a combination of the End Condition and the Schedule?
Check what these are on both and make them the same.
Tomislav Golubovic
Plant Solutions Engineer
Autodesk Australia / New Zealand
New AutoCAD Plant 3D Category!
The AutoCAD Plant 3D forum has moved into it's very own category page, and can no longer be found within the Additional Product Forums.
