AutoCAD Plant 3D Forum
Welcome to Autodesk’s AutoCAD Plant 3D Forums. Share your knowledge, ask questions, and explore popular AutoCAD Plant 3D topics.
Out of Spec item - leakage + 'open end' on iso
1 REPLY 1
vannmannen
369 Views, 1 Reply
I have a filter with DIN flange, while the connecting piping is ANSI.
First I place the DIN flange to the equipment and then I place an CS150 elbow to the flange. The connection between the DIN flange and the ANSI elbow shows a leakage point + the isometric separates the ANSI line and the DIN flange into separate drawings showing 'open end' connections.
How can I force Plant3D to accept the connection, or alternativly; force the iso to show connecion + spec break?
1 REPLY 1
Its probably missing a combination of the End Condition and the Schedule?
Check what these are on both and make them the same.
Tomislav Golubovic
Technical Specialist - Plant and Infrastructure
Autodesk Australia / New Zealand
Autodesk ANZ YouTube Channel
”Boost
