AutoCAD Plant 3D General DIscussion
Active Member
Matellezm
Message 1 of 2 (171 Views)
orthographic views rotated
171 Views, 1 Replies
01-16-2013 05:18 PM
We are finishing the modeling project and create the plans now spelling, Views generated within the plans by the orientation does not fit within the plane but rotated 90 degrees with respect to the size of the plane but we have a problem updating the view as we tour view in its original state but the area remains in place and need to edit the view, update and re-rotate.
Is there a better way to avoid the issue of views?
Product Support
Dan.Scales
Message 2 of 2 (138 Views)
Re: orthographic views rotated
01-18-2013 09:22 AM in reply to: Matellezm
If you rotate an ortho view the link to the model is broken so it is not possible to update. In this situation the only option is to recreate the view.
Dan
Dan Scales
Need installation help?
New AutoCAD Plant 3D Category!
The AutoCAD Plant 3D forum has moved into it's very own category page, and can no longer be found within the Additional Product Forums.
