We have our structure and doors modeled in MEP. When we make an orthographic section view that cuts through the walls, the walls dont show up. But they show up in a view from the top. I have attached a picture of the plan and the section.
Is there a way to make AutoCAD MEP or Architecture drawings work with the orthographic views?
OR . .is there a way to make doors in P3D? That would also solve my problem, if I could just do all of the walls and doors in P3D.
I realize this isn't ideal, but is there a way to convert the ACA objects into solids? Would this give you the ortho you need?
Just wondering....is there an object enabler for MEP stuff that might not have made it into your P3D install?
Peter: I tried that, but when you look at a solid in plan view, the "swing" of the door does not show up.
richos: I dont think so, but I'll check with my CADD Manger and see.
What I did as a workaround was to make a 2D/3D block. I made a block that had a "plan view" drawn in the XY and a profile view drawn in the XZ. Then I copied the XY plan view to an elevation above the walls, that way it shows up in the walls. Then I make my view cube for the plan high enough to show it, and my view cube for my profiles low enough that I dont show it.
I attached a block of my 2D/3D door.
