AutoCAD Plant 3D General DIscussion
Valued Contributor
13 Kudos
Post 1 of 11
Accepted Solution
Orthographic Drawings
694 Views, 10 Replies
09-07-2012 03:10 AM
When we use PLANTEQUIPMENTCONVERT to create equipment from AutoCAD XREFs the equipment does not display in the Orthographic drawings created.
Is your file XREF-ed as an overlay or as an attachment? Overlays won't show on orthos, attachments will.
Jörgen
Employee
7 Kudos
Post 2 of 11
Re: Orthographic Drawings
09-08-2012 11:04 PM in reply to: phwatso
You have to make the original file part of the project. Right mouse click on the folder in the project manager and select "Copy Drawing to Project". Then xref from there.
If my post answers your question, please mark it as an Accepted Solution, so that others can find answers quickly!
Jarrod Mudford
Plant Solutions Consultant
Global Services
Autodesk, Inc.
Distinguished Contributor
54 Kudos
Post 3 of 11
09-13-2012 03:57 AM in reply to: JarrodMudford
Even after you make xref from the project file, the orthographic will not be displayed.
If you XREF, orthographic will not be generated even if it is in project file.
I find its a bug of the software, tried several times.
Product Support
35 Kudos
Post 4 of 11
09-13-2012 04:37 AM in reply to: phwatso
If I convert AutoCAD objects using PLANTEQUIPMENTCONVERT and then the drawing is xreffed into another drawing I can create an Ortho that included the Xref equipment.
I tested this in Plant 2013, is that the version that you are using?
Dan
Dan Scales
Valued Contributor
10 Kudos
Post 5 of 11
09-13-2012 06:21 AM in reply to: phwatso
Jörgen
Product Support
35 Kudos
Post 6 of 11
09-13-2012 06:29 AM in reply to: Jorgen1990
Yes, it looks like overlayed Xrefs are the issue. Attached Xrefs work fine.
I believe that this has logged with our developers already.
Dan
Dan Scales
54 Kudos
Post 7 of 11
09-13-2012 11:01 PM in reply to: Dan.Scales
Yes, attachment in overlay only causing problems.
54 Kudos
Post 8 of 11
09-13-2012 11:05 PM in reply to: Arun_Kumar_K
Also, there is an issue in Orthographic. If i take the drawings from ASD, the ortho views are not proper. Already we logged this bug with development team. Hope it will be resoved in 2014 release. Because of this interfacing issue, we are not able to use the ASD and Revit.
Valued Contributor
13 Kudos
Post 9 of 11
09-18-2012 03:48 AM in reply to: phwatso
We Xref (attach) a part (grundfos pump model for example) into our piping model and then use plantequipmentconvert in the piping model to add nozzle information etc.
Which order/process should we be using to ensure they display in orthographic drawings?
Sorry for the delay in responding...
Valued Contributor
10 Kudos
Post 10 of 11
09-24-2012 02:09 AM in reply to: Dan.Scales
Dan
Hi
By my understanding, it is not an issue or a problem. Overlays are not supposed to show on orthos. If you want to see xref-s on orthos, insert them as attachments. The idea of overlay is that you can see the xref while working in your file and use it as a guidance, but leave it out of orthos.
Cheers,
Jörgen
Post to the Community
New Post
Need installation help?
New AutoCAD Plant 3D Category!
The AutoCAD Plant 3D forum has moved into it's very own category page, and can no longer be found within the Additional Product Forums.
Announcements
Are you interested in helping shape the future of the Autodesk Community? To participate in this brief usability study, please click here. Your time and input is greatly appreciated!
