AutoCAD Plant 3D Forum
Ortho Update View !!!!!!!!!!!!!!!
8 REPLIES 8
Message 1 of 9
thebearjed
1086 Views, 8 Replies
i am very upset at this latest "bug". after doing an update view on my ortho viewport it moves the whole viewport up and to the left. this makes all the annotations that i have spent hours adding useless. this is unacceptable!!!!!!!!
8 REPLIES 8
Message 2 of 9
alvaro.nimasco
in reply to: thebearjed
is this happening in 2012 too ?
old issue, the solution works for me though, see older post
regards
http://forums.autodesk.com/t5/AutoCAD-Plant-3D/Update-View-Changes-Position-of-Graphics-in-Paperspac...
Message 3 of 9
thebearjed
in reply to: alvaro.nimasco
2012 with SP 1
Message 4 of 9
jason.drew
We are currently looking into this issue. I have been able to reproduce the problem (randomly) and it seems to be realated to Plant 3D models that have XREFs attached. Are you using XREFs on your project? If so, what kind of models are you attaching? (regular ACAD 3D solids, model from another vertical - ACAD Architecture, Revit, etc.)
So far the workaround to "repair" an Ortho view is to:
1. Select the viewport that has shifted
2. Click on "Edit View" from the ribbon bar
3. Once the ortho view boundary selection comes up, just click "Update View" on the ribbon bar
4. The view will regenerate and it should be back to where it was before
5. If changes have been made to tags or properties, right-click on the view on Project Manager and select "Update annotations" (The annotations in paper space should still be linked to the model objects and the database)
Thank you,
Jason Drew
Designated Support Specialist
Message 5 of 9
Mudbay
This is happening to me when I change how much I want to show in the "ortho model" and then update, then my view moves. It would be nice if my layout in the view is on the same place. I'm using Plant 3D 2012.
/Mattias
Message 6 of 9
neonade
in reply to: Mudbay
Have this issue been fix on Plant 3D 2013?
Cheers
Message 7 of 9
thebearjed
no sir, it has not.
Message 8 of 9
EricNyh
in reply to: jason.drew
Thank you,
This still appears to be an issue with 2014.  Every time I open up a set of drawngs, AT LEAST one of the sheets needs to be updated.
Is this still being worked on?  My model is P3D everything with some Autocad 3D solids. Project broken up into lots of smaller models xref'd into a main model.
Message 9 of 9
2018 SP1.1 is also exhibits this phenomena.
And, there are no xref's in the base drawing.
”Boost
