AutoCAD Plant 3D Forum
Welcome to Autodesk’s AutoCAD Plant 3D Forums. Share your knowledge, ask questions, and explore popular AutoCAD Plant 3D topics.
Ortho tags are imperial & I need metric
2 REPLIES 2
MOLGRAND
599 Views, 2 Replies
I have done a small project using metric-metric (this was so i have the bolting correct) - the Isos run off nicely & show metcic sizes for the line no tages etc. However when I tag the ortho drg (see attached) the tagging is displaying imperial units - can anyone help in identifying a solution.
Gary
2 REPLIES 2
MOLGRAND
in reply to: MOLGRAND
Problem solved - all the tags converted to metric automatically when I started the computer up the next day!
AndyDavisCadline
Hi Gary,
Check out the setting of the Size Display Mode toggle on the Part Insertion panel of your Home tool ribbon.
It needs to be off to display the annotation in mm – otherwise it will display the units from the pipe spec.
Andy
Andy Davis
Industry Specialist
Cadline Ltd.
”Boost
