I have done a small project using metric-metric (this was so i have the bolting correct) - the Isos run off nicely & show metcic sizes for the line no tages etc. However when I tag the ortho drg (see attached) the tagging is displaying imperial units - can anyone help in identifying a solution.
Gary
Solved by MOLGRAND. Go to Solution.
Hi Gary,
Check out the setting of the Size Display Mode toggle on the Part Insertion panel of your Home tool ribbon.
It needs to be off to display the annotation in mm – otherwise it will display the units from the pipe spec.
Andy
