AutoCAD Plant 3D Forum
Welcome to Autodesk’s AutoCAD Plant 3D Forums. Share your knowledge, ask questions, and explore popular AutoCAD Plant 3D topics.
Ortho not cutting existing pipe
2 REPLIES 2
326 Views, 2 Replies
My company has transitioned to Plant3D from Autoplant about a year ago.  We have now started to work on additions to projects that had been completed in Autoplant years ago.  The problem I am having is when I created orthos that contain drawings with older existing piping that was done in Autoplant.  The Autoplant piping does not show in the orthos.  I have installed all the appropriate object enablers.  Has anyone run into this issue?  It is going to be disappointing if all our older models will need to be remodeled.
2 REPLIES 2
TomislavGolubovic
Is that model part of the project, or just a normal XREF?
Tomislav Golubovic
Technical Specialist - Plant and Infrastructure
Autodesk Australia / New Zealand
Autodesk, Inc.
Autodesk ANZ YouTube Channel
in reply to: TomislavGolubovic
These piping files have been added to the project in a piping folder and the pipe is the only thing in the drawing.  When attempting to cut I select the piping model I need, to be included in the ortho.  I've tried using different versions of the existing pipe drawings.  The only one I have been able to cut is a file that I have saved as version 2000 dwg, then I opened it in Microstation and saved as a dgn,  then I close and open it in Microstation again and save as a dwg.   For some reason this has made the files able to be cut and shown in the ortho.  I would prefer not to have to do this to all my existing piping files.  Any suggestions on how to get my old Autoplant files to work in Orthos?
”Boost
