JoeKay,
The Matchline annotation is just text. You can edit it after creating the view to say what you want.
As for Ortho layers, you need to make sure the layers and colors are setup correctly in you Title Block template (*.dwt) file. Then inside the project setup you will need to map the layers as needed.
