Hello!
I know that there are several threads with questons regarding Ortho Layer behaviour, but I have a specific question so I started a new thread.
I use Plant 3D 2014. I generate an ortho and I get the pipeline layers in ortho drawing coloured according to pipe colors in the model, which is cool. But when I change the pipeline colors in model and update the ortho view, colors won't change. Is this normal? Must I then create a new view to get the updated colors or is there any other way? It is annoying because I want to try out how different pipe colors look like on paper. I have all pipe colors in model set to ByLayer and I change color from the layer manager.
PS. I have the "use 3D model settings" (or something..) checked in the Projet Setup->Ortho settings
Jörgen
Solved by phwatso. Go to Solution.
Thank you for the reply. VISRETAIN in the piping model was set to 1, changed it to 0 but nothing changed, colors are still not updating.
Any other ideas?
Jörgen
