AutoCAD Plant 3D Forum
Welcome to Autodesk’s AutoCAD Plant 3D Forums. Share your knowledge, ask questions, and explore popular AutoCAD Plant 3D topics.
Ortho creation in Plant 3D with revit dwg exported backgrounds
4 REPLIES 4
746 Views, 4 Replies
We are currently working with AutoCAD Plant 3D 2012. All pipe routing we are doing with plant, but structural, architectural and General Arrangment models are being done in revit. The problem I am having is that the Revit DWG exports are huge files (about 75mb to 300mb) are causing ortho creation to take anywhere from 20 to 40 minutes per view. Can I export a revit file to a more compressed format or am I just doing something wrong? Any ideas would be appreciated.
4 REPLIES 4
dave.wolfe
Have you played with the setup options under Export > DWG Setups?
Dave Wolfe
Isaiah 57:15
Tips and Tricks on our blog: ASTI blog
EXPERT ELITE MEMBER
Plant 3D Wish list
in reply to: dave.wolfe
Yes... I am currently experimenting with exporting down to 07 and 04 formats to see if it makes the files more manageable for plant.
dave.wolfe
See if using Arch objects works for you.  I was able to produce an ortho with the Arch Objects included, and the files are much smaller.
Dave Wolfe
Isaiah 57:15
EXPERT ELITE MEMBER
Plant 3D Wish list
Tags (2)
Diego.Faria
Dave,
The files were indeed smaller (33 mb for ACIS versus 10 mb for ACAD Arch objects). The problem is that my resultant dwg is all messed up (see pictures attached).
The first is the ACIS (which is what i see in Revit) and the second is the ACAD Objects (messed up).
Any ideas on what's causing this?
I'm using both AutoCAD Plant 3D and Revit Arc/Str/MEP 2012 versions.
PS: Both work fine when creating an Ortho View
Diego Faria
LinkedIn
”Boost
