Hello
in an ortho-drawing I can place predefeined anntotations for different pipe parts and equipment and so on.
How can I place annotations with custom properties that I've created in in the P3D class definition.
Thanks in advance
Guido
Solved by GSC_HAYA. Go to Solution.
I found it...
Project configuration/Plant3d-DWG.../Plant3D class definition
When you select an item you find the ortho-annotations bottom-right
You can edit or add annotations.
