When using the Ortho Annotate command, I selected the pipe that I wanted to recieve the line number from and it worded fine. Except I want to edit the text style to show 3/32" size text and make it 0.85 width factor. How can I acheive this? It comes in as 1/8" and 1.00 width factor.
Solved by Dadspackard. Go to Solution.
That did not work. It works when I just use regular mtext, but when I use the Ortho Annotate command and click the pipe to reveal the line number, it comes in as 1/8” and 1.00 width factor. I even changes the text style through STYLE command to an off the wall style and retried it and still nothing. Comes in as Standard style, 1/8”H, 1.00 width factor. Got any other ideas?
... post a screenshot
i think you are in the wrong "Programm" or the window open , but outside your screen
cu cw
TWROGERS,
Lets try this
Go to Project Setup then go to down to Plant 3D DWG Settings
Plant 3D Class Definitions
Pipe Run Component
Under Properties scroll down to Annotation Style select/highlite it
Under Ortho Annotation Setup Select the style you want to edit
Select edit block. Block editor will open. Here you can add your text style you would like to use, height etc etc.
Now select the Atribute block text and change the properties to your standards.
Easier for me to show you in a screen cast then typing it out in text form.....
You are most welcome.
Glad to hear it worked out for you and giving me my First Kudos and Solution 🙂
Hopefully more to come
tom.malas,
Would you happen to also know how to edit the leader for ortho text as well? Ex. insert full line number, you are promted to rotate text or add leader.
TWROGERS,
Take a look at this thread https://forums.autodesk.com/t5/autocad-plant-3d-general/annotation-leader/td-p/3094356/highlight/tru...post number 8 is this what you are looking for?
If you not could you explain futher on what you need?
Does anyone have some viewstyles for 2018 Orthogen that they'd like to share?
shawnbrodie@gmail.com
Thanks you in advance
Shawn
