AutoCAD Plant 3D Forum
Welcome to Autodesk’s AutoCAD Plant 3D Forums. Share your knowledge, ask questions, and explore popular AutoCAD Plant 3D topics.
Ortho and 3D model - True Colour -> AutoCAD Index Colour Fix
4 REPLIES 4
damian_willcox
1310 Views, 4 Replies
Several of you have run into an issue where the 'Autocolouring' that happens by the Plant 3D Project for things like colourbysize, etc is resulting in assigning true colour values (i.e. 0, 255,0) instead of AutoCAD Colour '3' for example, which in turn is causing plotting issues for both the model and downstream, the Orthos.
DISCLAIMER: The attached lisp file is unsupported and to be used or not used at YOUR OWN RISK.
What this lisp does is convert a selection of objects or ALL objects in either the model OR the Ortho from using true colour to Index colour.
1. to load, enter command APPLOAD, and select and load the lisp file
2. In the 3D model:
a. Use command FIXACI to allow you to select specific objects to convert to AutoCAD Index colour.
b. Use command FIXACIALL to allow you to convert ALL AutoCAD objects to AutoCAD Index colour.
3. In the ORTHO model:
a. Use command FIXACIBLOCK to allow you to select specific ortho blocks to convert to AutoCAD Index colour.
b. Use command FIXACIBLOCKALL to allow you to convert ALL AutoCAD blocks to AutoCAD Index colour.
4. If you are using true colour anywhere in your models, you should take care to avoid the commands that convert ALL objects if you want to retain the true colours, as opposed to the AutoCAD Index Colours
5. Remember the disclaimer, and test first - undo and not saving work if something terrible happens, but this lisp is unsupported.
6. This message will self destruct.
Damian Willcox
Sr. XD Architect
4 REPLIES 4
FProcp
in reply to: damian_willcox
Thanks Damian, this worked for my "Ortho Views".
Franco
GMT +08:00
Good to hear!
-d
Damian Willcox
Sr. XD Architect
It would be great if this lisp had an additional line that would remove all the center lines from the Ortho.
Could this be done?
hi !
there is a lsp that can add true colors to the indexed autocad color table ? i don't wont to replase the true color with a indexed one !
thank you !
”Boost
