Adding a Orifice Flange to a Spec I noticed that there is some incorrections in dimensions.
1° - The instrument connection for the diameters lower than 4" are incorrect; The diameter of hole (drill) is 1/4" an 3/8", but the NPT connection is 1/2".
2° - On length dimension was forgotten the raised face dimension (0.06") both in "L" and in "B" dimensions ; In a common WN flange the dimension "B" is does not sum the raised face, but the total length is correct; In the case of the orifice flange the "B" dimension can not be ignored, because the sum of 0,94" plus 0.06" must be 1".
Check annex image.
Att.
Gabriel Nogueira.
The way I read it, you should just change the item to suit the dimensions you require.
Yes, that is a solution for now.
I pointed out that, in order for the catalog could be fixed in the next versions.
Gabriel,
Thank for this post. I noticed this as well and was extremely confused by it. I assumed Plant 3D would use the standards they call out correctly! From now on, I will double check. Hopefully they fix this and recheck all specs in later versions.
-Bryan A.
