AutoCAD Plant 3D Forum
Order list
10 REPLIES 10
Message 1 of 11
arjan.gorinsekéman-engineering.be
1081 Views, 10 Replies
Order list
Is it possible to generate a order list of the entire project?
I need to know how many meters pipe; qty of tees,weldolets,valves,....
10 REPLIES 10
Message 2 of 11
we as ACPlant Consult have a tool called PlantReporter which allows you to create all kinds of reports from P&ID and Plant 3D as well as bill of materials from Plant 3D. You can get more info from our homepage www.acplant.com
Kind regards,
Carsten
Message 3 of 11
I can't generate any reports from my plant 3d drawing
If I go to Edit query and select Plant 3d Classes I cannot select anything.
If I choose the standard reports for example ACP Line list the report is empty
Am I doing something wrong?
Message 4 of 11
Hi Arjan,
You are not doing anything wrong. The reports you see in project setup are
for the P&ID workspace. We are aware of this issue and are working to
resolve it in a future release.
Jorge
"arjan.gorinsek%C3%A9man-engineering.be" wrote in message
news:6372573@discussion.autodesk.com...
> Hello,
> anything.
> empty
Message 5 of 11
Atached document explains how do this using Microsoft Access.
Siva (Autodesk)
Siva Thankappan
Technical Sales, Plant Solutions, Asia Pacific
Autodesk Singapore
Message 6 of 11
Many thanks Siva,
I have manage to modify the Pipe and Components Quantity query and add the fields that I need and it is working just fine.
But it is just missing 2 IMPORTANT things to count.
1 - Gaskets
2 - Bolts
Siva can you modify the access file query to count the Gaskets and Bolts also?
Abílio Ramos
Message 7 of 11
I have found that P3D is not generating SpecRecordId for the gaskets and bolts.
Any idea how to solve this?
Message 8 of 11
I have attached the modified query "Pipe and components with bots and gaskets". Please take a look. SpecRecordId for bolts and gaskets are in the Fastners table.
thanks, Siva (Autodesk)
Siva Thankappan
Autodesk Singapore
Message 9 of 11
Many thanks, Siva
It is working but is not getting the line number which belongs! Also the quantity displayed is not correct is in thousands
Can you fix this?
You have the project in this link to test:
http://www.pipedrafting.com/40155.zip Edited by: abilioramos on Apr 22, 2010 1:16 PM
Message 10 of 11
Please take a look at the attached file. I checked for bolts quantity, they are coming OK in my machine, it could be a windows locale thing - you use , (coma) for decimal (.). Anyway I tried something, let me know if it is not fixed, and would require further research.
Thanks, Siva (Autodesk).
Siva Thankappan
Autodesk Singapore
Message 11 of 11
Thanks Siva ,
I have modified the (coma) for decimal (.) in the Regional and Language Options and now its working just fine.
Abílio Ramos
”Boost
