Dear sir/madam,
I made a custom valve body with custom actuator. This is Danfos SVA-S Stop valve. You have port 1 from the bottom, port 2 from the side and spindle (operator) on the top side. The program understand not that operator is on the top side. Plant 3d see no difference between valve and valve angle. I mean that if you turn the valve on north (straight valve), the program understand that operator is turned on north side. But if you do the same with angle valve, that means that you turn to the north second port, but the program shows you that operator is turned also to the north (with port 2). I hope that you understand. It is difficult to explain. See picture
What version of Plant 3D are you using.
Could you also confirm what iso skey and type you are using?
Dan
