AutoCAD Plant 3D Forum
Welcome to Autodesk’s AutoCAD Plant 3D Forums. Share your knowledge, ask questions, and explore popular AutoCAD Plant 3D topics.
Indesh
238 Views, 2 Replies
OPC
I have created an OPC..my variable are product,from/to and dwg no.(to)....
i have created 2 pids and this works fine i do get all my data automatically,
note that my frm/to are linked to the equipment tag...which works fine.
my issue is that if i have a line in pid 1 passing in pid 2 where a tie in is done and finally gos to pid 3 where it is connected to a vessel..
the results are as follows
pid 1 : it gives me the dwg number ,the product but not the from /to.
pid 2: it gives me all datas.
pid 3: it gives me the dwg number ,the product but not the from /to.
what i understand from the results is as if your common line jumps 1 pid it can't read...it reads only i pid after!!!!!
can anyone help please...
2 REPLIES 2
eadkins73
in reply to: Indesh
What happens if you disconnect the tie in on PID #2?
Ed Adkins
EA2 Engineering
www.ea2eng.com
Indesh
in reply to: eadkins73
nothing happens as my main line is on p&id 3
”Boost
