Hi, insert a custom valve in spec editor and all good, but when the income on the 3d no generated flanges automatic, how i can solve this?.
Solved by Gokhan_Kaya. Go to Solution.
Hi Pinar
You can check your custom part (valve) ports on Spec Editors , it must have FL
you can check ports of valve in Autocad Plant
I tried to explain in the picture below
if you can send me valve properties info, i can help more than
Gökhan Kaya
Tehcnical Manager
Autodesk Inventor Certified Professional 2015
LinkedIn
MSI WS 60 i7 Quadro M2000M
Gokhan is right, as per your snapshot, the valve is not flanged type "FL"
Best Regards,
Pat Andres
Autodesk Expert Elite
Plant 3D Administrator
GHD Manila
