AutoCAD Plant 3D Forum
Welcome to Autodesk’s AutoCAD Plant 3D Forums. Share your knowledge, ask questions, and explore popular AutoCAD Plant 3D topics.
Off Page Connectors
2 REPLIES 2
384 Views, 2 Replies
Off Page Connectors
We are having problems with Off Page Connectors & Utility Connectors.
After the connection is made if we have to edit anything or move the connector, they go haywire.
Often when an existing connector is modified the end of the piping line graphically breaks away from the connector. If either is moved the connector jumps to a random area of the drawing and cannot be undone. Both lines on both drawings then need to be deleted and rerouted from scratch (including valves & interments)
Help please
2 REPLIES 2
jason.drew
The off-page connectors you are using, have they been modified in any way from the original OoTB (out-of-the-box) connectors?
Jason Drew
Designated Support Specialist
in reply to: jason.drew
The off page connectors are custom to comply with a customer standard.
”Boost
