Hello, in Plant3D 2014 it's posible to connect two off page connectors with the same direcction, for eample TO with TO. I think that it will be problems in projects.
I have reproduced this behavior and logged it with our developers.
Dan
Also within 2014, We are unable to delete Off Page Connectors. I understand you are to right click the OPC, and then click erase. Selecting it and hitting delete should not be much different. In reality, neither work. So Now I have a series of P&ID's where the non-deletable OPC's are off the Title Block, and just floating.
Please advise a fix!
Turns out if you run an AUDIT on the drawings where the OPC's do not delete, they will automatically delete once the AUDIT has been run.
