Hi Scott,
I do not believe this is related to the specs. It appears the entity lost
its link to the project database. The only way I know to fix this is to
erase it and re-draw it. Are you working in a multi-user environment with a
network project?
Jorge
"sreid13" wrote in message news:6362376@discussion.autodesk.com...
I am wondering if anyone has come across this or not where object in a 3D
drawing loose its intelligence. I'm pretty sure it was because i copied in
an updated spec but the parts that were different between the versions of
the specs weren't modified.
Is there a way to make it work again without reverting back to the previous
spec (which i dont have anymore)?
I'm still updating the specs and the project is only a test but it would be
good to know if there is a work around or not and also so i dont do it
again.
I've attached a pic showing what it looks like when a part is selected and
the properties window showing no info.
Cheers,
Scott
