AutoCAD Plant 3D General DIscussion
Valued Contributor
eadkins73
Message 1 of 4 (549 Views)
Object reference not set to an instance of an object
549 Views, 3 Replies
10-08-2013 02:44 PM
I got the failure "Object reference not set to an instance of an object" when running an iso (see attached).  I can't seem to figure out why it's doing that.  An ideas?
Product Support
VinodBalasubramanian
Message 2 of 4 (540 Views)
Re: Object reference not set to an instance of an object
10-08-2013 08:36 PM in reply to: eadkins73
Are you generating ISO from PCF or from the model. Can you send us your model drawing for further testing and also let me know which release of Plant 3D you are working with.
Vinod Balasubramanian
New Member
madaspeed
Message 3 of 4 (469 Views)
10-24-2013 09:26 PM in reply to: eadkins73
I am having the same issue, creating an ISO with Plant3D 2013.
Iso Creation start time : 25/10/2013 2:48:04 PM
Iso Creation finish time: 25/10/2013 2:48:10 PM
Duration                : 00:00:06
Output folder           : P:\237208\CADD\MODELLING\Isometric\Santos\ProdIsos\Drawings\Drawings
1 Isometric(s) were not able to be created:
P:\237208\CADD\MODELLING\BIG LAKE CIEP\Isometric\Santos1\PCFs\350-RG-11598-006.pcf
INFO    - Loading input: 'P:\237208\CADD\MODELLING\BIG LAKE CIEP\Isometric\Santos1\PCFs\350-RG-11598-006.pcf'
INFO    - Loaded '2' model(s).
INFO    - Processing: '350-RG-11598-006-1'.
INFO    - Model-based split has been done. The model has been split into 2 models.
FAILURE - Object reference not set to an instance of an object.
Valued Contributor
eadkins73
Message 4 of 4 (420 Views)
11-07-2013 12:19 PM in reply to: eadkins73
Vinod,
The issue is caused by a Victaulic coupling (from the victaulic catalog on the autodesk website) on the branch of a tee.  Once I removed the vic (or moved it to the unassigned line number) the iso ran.
Also, somewhat related, I have an issue with the iso turing into an exploded view of the line because the weld dot is assigned to the connecing line and not to the line of the iso.  This is also at the branch of a BW tee.  Changeing which line the weld dot is assigned to "fixes" the iso.
See Attached...
Announcements
Need installation help?
New AutoCAD Plant 3D Category!
The AutoCAD Plant 3D forum has moved into it's very own category page, and can no longer be found within the Additional Product Forums.
