AutoCAD Plant 3D Forum
Welcome to Autodesk’s AutoCAD Plant 3D Forums. Share your knowledge, ask questions, and explore popular AutoCAD Plant 3D topics.
nozzle size bug
1 REPLY 1
normad
317 Views, 1 Reply
nozzle size bug
Hi guys, For some reason when i add a nozzle and select my unit as 'inches' the nozzle becomes tiny!
The nozzle in the background is the exact same except the unit is selected as 'mm' and the pressure class is 10.
this is definitely not a 2" nozzle 😕
and i cant use unit mm because then it'll be incompatible with the rest of the network.
even more weirdly the size is tiny for all sizes except 80.. which is what i used earlier..
any help would be greatly appreciated..
thanks a bunch
1 REPLY 1
When the project was first created, a selection was required to “Specify unit settings”.  Choices are Imperial or Metric (with reporting either in Millimeters or Inches (Mixed Metric). Check to see if this is a case of mismatched units.
Martin Stewart
AEC Support Specialist
”Boost
