AutoCAD Plant 3D Forum
Nozzle Problem
5 REPLIES 5
jvelezt
673 Views, 5 Replies
Nozzle Problem
Hello All
how do I control this distance between the nozzle and the tank?
5 REPLIES 5
quentin.contreras
in reply to: jvelezt
I am not sure what version of AutoCAD Plant 3D you are using. I was able to test this using AutoCAD Plant 3D 2014 Ext 2, then used PLANTEQUIPMENT create the tank. I did not see the gap issue you are seeing. Is there anything different you are using besides the out of the box settings?
If my post answers your question, please mark it as an Accepted Solution, so that others can find answers quickly!
Quentin Contreras
Technical Support Specialist
EricNyh
in reply to: quentin.contreras
Quentin, if you uncheck the "make perpendicular" box, there will be a gap for sure.  Looks like your nozzle and vessel are smaller than the ops, don't know if that makes a difference.
jvelezt
in reply to: EricNyh
I have installed the Plant 3d 2014. did not I have the ext. 2
quentin.contreras
It appears you have no updates installed with your AutoCAD Plant 3D 2014. Since you have no updates installed you should go ahead and install the Service Pack 1.
Also, with regards to unselecting the perpendicular box, when I unselect it in my model it still does not look like yours. I would suggest you create a new Plant 3D drawing and use the PLANTEQUIPMENTCREATE and see if the same issue still occurs with trying edit the tank with a new drawing.
Quentin Contreras
jvelezt
quentin
This solve the problem, the service pack solve this, but the equipment created don not update i need rebuild all equipment
”Boost
