AutoCAD Plant 3D Forum
Welcome to Autodesk’s AutoCAD Plant 3D Forums. Share your knowledge, ask questions, and explore popular AutoCAD Plant 3D topics.
Not using my elbows from the spec
3 REPLIES 3
377 Views, 3 Replies
I have just realised that while routing pipework, the software is not using my elbows which i created. it is inserting elbows, but not ones that i created and they are not from the spec.
How do i tell p3d to use my elbows?
3 REPLIES 3
TomislavGolubovic
if there is something wrong with the spec, or the connection settings, it might be using parts from the Placeholder spec, that is in your project.
Can you post your spec here? And which version of P3D are you using?
Tomislav Golubovic
Technical Specialist - Plant and Infrastructure
Autodesk Australia / New Zealand
Autodesk, Inc.
Autodesk ANZ YouTube Channel
Attila.Vallyon
Or you turend on accidentally the Pipe Bend button?
Attila Vallyon
in reply to: Attila.Vallyon
yes, it was the pipe bend button.
thanks
”Boost
