AutoCAD Plant 3D Forum
Not using my elbows from the spec
3 REPLIES 3
phil.cooper
374 Views, 3 Replies
I have just realised that while routing pipework, the software is not using my elbows which i created. it is inserting elbows, but not ones that i created and they are not from the spec.
How do i tell p3d to use my elbows?
3 REPLIES 3
if there is something wrong with the spec, or the connection settings, it might be using parts from the Placeholder spec, that is in your project.
Can you post your spec here? And which version of P3D are you using?
Tomislav Golubovic
Technical Specialist - Plant and Infrastructure
Autodesk Australia / New Zealand
Autodesk, Inc.
Autodesk ANZ YouTube Channel
Or you turend on accidentally the Pipe Bend button?
Attila Vallyon
yes, it was the pipe bend button.
thanks
”Boost
