AutoCAD Plant 3D Forum
Welcome to Autodesk’s AutoCAD Plant 3D Forums. Share your knowledge, ask questions, and explore popular AutoCAD Plant 3D topics.
Not supported in a non P&ID drawing file.
2 REPLIES 2
onurozsu
946 Views, 2 Replies
Dear all,
I try to use AutoCAD Plant 3D educational version. When I try to add anything on a new drawing, or sample drawing or etc
"This tool is not supported in a non PNID drawing file"
 Some user have same problem like me (http://forums.autodesk.com/t5/AutoCAD-Plant-3D/P-amp-ID-Error/td-p/3817121,http://forums.autodesk.com/t5/AutoCAD-P-ID/This-tool-is-not-supported-in-a-non-PNID-drawing-file/td-...) but I can`t solve my problem.
I have changed the regional and language settings of my computer and same problem procedd again and again.
Can anyone help me?
(also I try uninstall and install again Plant 3D but it didn`t work)
Tags (1)
2 REPLIES 2
muh.ender
in reply to: onurozsu
Here is the exact solution for "this tool is not supported in a non p&id drawing file" error.
Go to control panel > time,language and region > region > change location > choose USA from the location tab. And then click administrative tab. choose English as the language for non-unicode programs.
It works. I have just tried.
Thanx and bye.
mehmet_aktas
in reply to: muh.ender
I had the same problem and your solution worked out. Thanks!
”Boost
