AutoCAD Plant 3D General DIscussion
Active Member
1 Kudo
Post 1 of 5
Accepted Solution
nooby
296 Views, 4 Replies
04-30-2012 07:44 AM
Is there any tutorial that shows how to create project including demonstration how to draw example elements - like riser to valves to tank ... I could not find what to draw first - PID or Model. I did start a project, but I have no idea how to actually draw it correctly. What is best philosophy or best technics that should be used?
A P&ID is usually the controlling document for the Plant. It defines the equipment, pipe sizes, specs, service and other variables that are required to build the plant. It lists all the valves, instrumentation everything. A Process Engineer is usually the person who might sketch this, then have it drawn by a P&ID designer.
From this, you create a model. The P&ID elements (lines and in-line fittings) can be drag-n-dropped from the P&ID into the model. As for layout, thats entirely dependant on the site, structure, etc. After this, you then get into doing Ortho drawings and Isometrics for production.
Employee
3 Kudos
Post 2 of 5
Re: nooby
05-01-2012 10:30 AM in reply to: kmankov
Try the links posted here: http://autocad.autodesk.com/?nd=plant_online_help2
Pat Jenakanandhini
Product Manager
Plant Solutions - AEC
Employee
52 Kudos
Post 3 of 5
Re: nooby
05-01-2012 03:19 PM in reply to: kmankov
Tomislav Golubovic
Plant Solutions Engineer
Autodesk Australia / New Zealand
Autodesk, Inc.
Active Member
1 Kudo
Post 4 of 5
Re: nooby
05-01-2012 03:31 PM in reply to: TomislavGolubovic
Thank you. How to draw a line at 45deg in PID? (riser)
Employee
52 Kudos
Post 5 of 5
Re: nooby
05-01-2012 04:41 PM in reply to: kmankov
Right click on the project in Project Manager, and select Properties.
From this new window, expand the "P&ID DWG Settings" then go to "Line Settings" and look for the tick box down the bottom marked "Create ortho schematic lines"
Tomislav Golubovic
Autodesk, Inc.
Post to the Community
New Post
Need installation help?
New AutoCAD Plant 3D Category!
The AutoCAD Plant 3D forum has moved into it's very own category page, and can no longer be found within the Additional Product Forums.
Announcements
Are you interested in helping shape the future of the Autodesk Community? To participate in this brief usability study, please click here. Your time and input is greatly appreciated!
