AutoCAD Plant 3D Forum
Welcome to Autodesk’s AutoCAD Plant 3D Forums. Share your knowledge, ask questions, and explore popular AutoCAD Plant 3D topics.
nooby
4 REPLIES 4
kmankov
419 Views, 4 Replies
nooby
Is there any tutorial that shows how to create project including demonstration how to draw example elements - like riser to valves to tank ... I could not find what to draw first - PID or Model. I did start a project, but I have no idea how to actually draw it correctly. What is best philosophy or best technics that should be used?
4 REPLIES 4
jenakap1
in reply to: kmankov
Try the links posted here: http://autocad.autodesk.com/?nd=plant_online_help2
Pat Jenakanandhini
Product Manager
Plant Solutions - AEC
TomislavGolubovic
A P&ID is usually the controlling document for the Plant. It defines the equipment, pipe sizes, specs, service and other variables that are required to build the plant. It lists all the valves, instrumentation everything. A Process Engineer is usually the person who might sketch this, then have it drawn by a P&ID designer.
From this, you create a model. The P&ID elements (lines and in-line fittings) can be drag-n-dropped from the P&ID into the model. As for layout, thats entirely dependant on the site, structure, etc. After this, you then get into doing Ortho drawings and Isometrics for production.
Tomislav Golubovic
Technical Specialist - Plant and Infrastructure
Autodesk Australia / New Zealand
Autodesk ANZ YouTube Channel
kmankov
in reply to: TomislavGolubovic
Thank you. How to draw a line at 45deg in PID? (riser)
TomislavGolubovic
Right click on the project in Project Manager, and select Properties.
From this new window, expand the "P&ID DWG Settings" then go to "Line Settings" and look for the tick box down the bottom marked "Create ortho schematic lines"
Tomislav Golubovic
”Boost
