AutoCAD Plant 3D General DIscussion
Valued Contributor
0 Kudos
Post 1 of 4
Nominal Size
230 Views, 3 Replies
12-22-2011 11:40 AM
Can you turn the NS off so that it does not come in when ISO's are created? BOM takes care of size so I don't want the NS on the drawings.
2 Kudos
Post 2 of 4
Re: Nominal Size
12-22-2011 10:18 PM in reply to: scoggin
Yes
Go to IsoConfig.xml and find <PropertyChangeScheme Name="Size" AnnotationStyle="Standard" Format="{0} NS" Grouping="true" Alignment="FlatHorizontal" LeaderStyle="AsNeeded" Filter="NotBoltWeldFlangeGasket" Field="Size" Placement="Along" />
Locate Format=“{0} NS” ,change the value of Format to Format=“ ”.
After modifing ,you will get <PropertyChangeScheme Name="Size" AnnotationStyle="Standard" Format=" " Grouping="true" Alignment="FlatHorizontal" LeaderStyle="AsNeeded" Filter="NotBoltWeldFlangeGasket" Field="Size" Placement="Along" />
Close and save the IsoConfig.xml, and create isometric again, you will get isometris drawing without NS shown
Valued Contributor
0 Kudos
Post 3 of 4
Re: Nominal Size
12-23-2011 04:58 AM in reply to: scoggin
Thank you!:smileyhappy:
Valued Mentor
80 Kudos
Post 4 of 4
Re: Nominal Size
12-24-2011 10:07 AM in reply to: scoggin
Is posible to change it to mm (in default configuration is inch)?
Yury Bogdanov
ASIDEK(Grupo CT) - Partner Directo de Autodesk
Barcelona (Spain)
New AutoCAD Plant 3D Category!
The AutoCAD Plant 3D forum has moved into it's very own category page, and can no longer be found within the Additional Product Forums.
