AutoCAD Plant 3D General DIscussion
PatrickByrne
Message 1 of 4 (597 Views)
No Plant 3D Properties in Navisworks
597 Views, 3 Replies
11-12-2012 05:07 PM
I must be doing something wrong.
When I click on a Plant 3D object in Navisworks 2013 there is no useful information except source file and layer. When I click on a CadWorx pipe item I get Short Description, Size, Long Description, Tag, Line number, Specification, Database code, Weight and Length.
Since Plant 3D and Navisworks are Autodesk products can somebody confirm this pipe information is also available for Plant 3D objects we will then know it is our setup
Are your object enabler's installed for Navisworks?
dave.wolfe
Message 2 of 4 (595 Views)
Re: No Plant 3D Properties in Navisworks
11-12-2012 05:41 PM in reply to: PatrickByrne
Dave Wolfe
Isaiah 57:15
ECAD, Inc.
Tips and Tricks on our blog: Process Design, from the Outside
A P3D Authorized Reseller
Plant 3d Wish list: https://plant3d.uservoice.com/
PatrickByrne
Message 3 of 4 (591 Views)
11-12-2012 06:20 PM in reply to: dave.wolfe
Hi Dave,
We had the object enabler installed, but I had not restarted the machine. It looks good now. Thanks
PatrickByrne
Message 4 of 4 (585 Views)
11-12-2012 07:18 PM in reply to: PatrickByrne
Further to above, we had the 2012 object enabler installed to match 2012 Plant 3D, we needed to install the 2013 object enabler to match 2013 Navisworks.
New AutoCAD Plant 3D Category!
The AutoCAD Plant 3D forum has moved into it's very own category page, and can no longer be found within the Additional Product Forums.
