AutoCAD Plant 3D Forum
No Plant 3D Properties in Navisworks
3 REPLIES 3
PatrickByrne
1437 Views, 3 Replies
I must be doing something wrong.
When I click on a Plant 3D object in Navisworks 2013 there is no useful information except source file and layer. When I click on a CadWorx pipe item I get Short Description, Size, Long Description, Tag, Line number, Specification, Database code, Weight and Length.
Since Plant 3D and Navisworks are Autodesk products can somebody confirm this pipe information is also available for Plant 3D objects we will then know it is our setup
3 REPLIES 3
dave.wolfe
in reply to: PatrickByrne
Are your object enabler's installed for Navisworks?
Dave Wolfe
Isaiah 57:15
Tips and Tricks on our blog: ASTI blog
EXPERT ELITE MEMBER
Plant 3D Wish list
PatrickByrne
in reply to: dave.wolfe
Hi Dave,
We had the object enabler installed, but I had not restarted the machine. It looks good now. Thanks
PatrickByrne
Further to above, we had the 2012 object enabler installed to match 2012 Plant 3D, we needed to install the 2013 object enabler to match 2013 Navisworks.
”Boost
