I am trying to insert a lug butterfly valve with a spectacle blind between two flanges. P3D gives me this error "No connection defined for end types wf and lug in the config file". I assume it has something to do with the machine bolts are not long enough. Anyone one know how to fix?
Solved by jabowabo. Go to Solution.
You are going to have to set up a connection type to tell Plant 3D what to do when a wafer end type connects to a lug end type. Go to Project Setup/Plant 3D DWG Settings/Piping Connection Settings/Simple Joints/Add. Here is an example (not tested):
