AutoCAD Plant 3D Forum
Welcome to Autodesk’s AutoCAD Plant 3D Forums. Share your knowledge, ask questions, and explore popular AutoCAD Plant 3D topics.
New Connection Type in Project setup for Laminations (GRP)
5 REPLIES 5
Hermann.Semlitsch
812 Views, 5 Replies
hi,
how i can add a new connection type in the project setup?
because the Pipe material is Glass Reinforced Plastic and the have laminations instead of welds. for this i need a new connection Parts in 3D ( example see attached file) and something in Isometrics (Description in the Weld list / Symbols / ......)......
thanks
Hermann
5 REPLIES 5
In Plant3D, type PLANTENDCODES and you can add new end codes. In the Catalog and Spec editor, you can manually type in the same End Codes in the parts editor to match the new ones you just created.
In the Project Properties, have a look at the Piping Connection Settings and add your new connections to the list with whichever fasteners it requires.
Tomislav Golubovic
Technical Specialist - Plant and Infrastructure
Autodesk Australia / New Zealand
Autodesk, Inc.
Autodesk ANZ YouTube Channel
thanks, but i know this stuff with the endcodes. i want to add a complette new connection Type in to the system. how i can make this because this will effect a lot (3D, 2D, Isos)
i attached files for example what i mean.
thanks
ah ok, gimme a sec
Tomislav Golubovic
Autodesk, Inc.
Having GRP issues aswell. Did anyone look into this?
hi,vannmannen
i have recieved some emails according to this.
they told me that this is at the moment not possible to add a new connection type but they will note this in the develeopment.
the only way is to change one of the existing connection types(not used) into this what you need.
”Boost
