AutoCAD Plant 3D General DIscussion
Hermann.Semlitsch
Message 1 of 6 (440 Views)
New Connection Type in Project setup for Laminations (GRP)
440 Views, 5 Replies
08-24-2012 01:18 AM
hi,
how i can add a new connection type in the project setup?
because the Pipe material is Glass Reinforced Plastic and the have laminations instead of welds. for this i need a new connection Parts in 3D ( example see attached file) and something in Isometrics (Description in the Weld list / Symbols / ......)......
thanks
Hermann
Employee
TomislavGolubovic
Message 2 of 6 (415 Views)
Re: New Connection Type in Project setup for Laminations (GRP)
08-26-2012 03:27 PM in reply to: Hermann.Semlitsch
In Plant3D, type PLANTENDCODES and you can add new end codes. In the Catalog and Spec editor, you can manually type in the same End Codes in the parts editor to match the new ones you just created.
In the Project Properties, have a look at the Piping Connection Settings and add your new connections to the list with whichever fasteners it requires.
Tomislav Golubovic
Plant Solutions Engineer
Autodesk Australia / New Zealand
Hermann.Semlitsch
Message 3 of 6 (402 Views)
08-27-2012 08:40 AM in reply to: TomislavGolubovic
thanks, but i know this stuff with the endcodes. i want to add a complette new connection Type in to the system. how i can make this because this will effect a lot (3D, 2D, Isos)
i attached files for example what i mean.
thanks
Employee
TomislavGolubovic
Message 4 of 6 (390 Views)
08-27-2012 04:32 PM in reply to: Hermann.Semlitsch
ah ok, gimme a sec
Tomislav Golubovic
Valued Contributor
vannmannen
Message 5 of 6 (274 Views)
12-05-2012 06:10 PM in reply to: TomislavGolubovic
Having GRP issues aswell. Did anyone look into this?
Hermann.Semlitsch
Message 6 of 6 (268 Views)
12-05-2012 08:34 PM in reply to: vannmannen
hi,vannmannen
i have recieved some emails according to this.
they told me that this is at the moment not possible to add a new connection type but they will note this in the develeopment.
the only way is to change one of the existing connection types(not used) into this what you need.
New AutoCAD Plant 3D Category!
The AutoCAD Plant 3D forum has moved into it's very own category page, and can no longer be found within the Additional Product Forums.
