Dear Peter Quinn !
Thanks for the help!
But I still have problems:
1. Your best bet for a unique item, such as a flowmeter would be to use a
Custom Component ...
Unfortunatelly I can create only Universal_ET end type parts, i need FL end type.
2. You can copy an existing catalog items and update the parameters
and descriptions.
I could not find miscellaneous inline components with flanged ends and with editable parametric model in the part geometry panel.
There are flanged valves with editable parametric models, but those are no good for this purpose since they have hand lever or actuator. And I cannot remove them from the valve body when I insert them in a pipe spec (altough the valve body looks similar to a compensator in the model).
I can copy and rename a valve to a flowmeter or a compensator, but it looks strange with a hand lever when I insert it into the model.
If the Autodesk could prepare custom flanged ( metric and ANSI ) inline components with editable parametric model for universal use, and release them in a catalog that would be the best.
That way the users could prepare themselves inline flanged components easily.
Best regards,
Attila Vallyon
Attila Vallyon
